But is it paella?
Moderators: refs unsheep, ChickenMug
- judasmuppet
- poofy
- Missin' Jimmy level: 0
But is it paella?
Chorizo Paella
Ingredients:
2 tbs olive oil
1 chorizo sausage, thinly sliced (I use two)
1 green capsicum (bell pepper), halved, deseeded, finely chopped
1 zucchini, thinly sliced
1 brown onion, halved, thinly sliced
2 garlic cloves, peeled, thinly sliced
1 tsp paprika
500g long-grain brown rice
1 x 400g can diced tomatoes
1.25L (5 cups) water
3 tsp beef or vegetable stock powder
150g (1 cup) frozen peas
Salt & freshly ground black pepper
1/3 cup coarsely chopped fresh continental parsley
Method:
1. Heat half the oil in a frying pan over medium heat. Add chorizo and cook, stirring, for 2-3 minutes or until golden. Add capsicum and zucchini, and cook, stirring, for 5 minutes or until golden and tender. Transfer to a plate.
2. Heat remaining oil in the same pan. Add onion and garlic and cook, stirring, for 5 minutes or until soft. Add paprika and stir for 1 minute or until aromatic. Add rice and stir to coat in spice mixture.
3. Add tomato, water and stock powder and bring to the boil. Reduce heat to low. Cover and simmer for 45-50 minutes or until liquid is almost absorbed. Add the peas, chorizo, capsicum and zucchini and stir to combine. Cover and cook for 10 minutes or until vegetables are tender. Taste and season with salt and pepper.
4. Remove from heat. Set aside, covered, for 10 minutes. Transfer to a serving bowl and sprinkle with parsley to serve.
Serves at least four, but you'd have to be pretty hungry to eat that much in one go.
Ingredients:
2 tbs olive oil
1 tsp paprika
Method:
I SINCERELY HOPE YOU CUNTS NEVER BUILD PLANES
- judasmuppet
- poofy
Hitman
You guys are missing the point.
I always put chorizo in paella.
You are using the wrong rice.
With Paella you should always use a MEDIUM GRAIN RICE...
Other differences are the obvious adding of seafood, and I always add some chicken.
Omit the zucchini.
Use a good home made chicken or seafood stock instead of the water and powdered veg stock.
I would use coriander instead of parsley. Maybe add a little white wine and lemon.
Probably the most important ingredient missing from your recipe is Saffron...
Omit the zucchini.
- Chantel
- canadian sympathizer
- Twitter: http://www.twitter.com/chantelbann
lynnjen/mod/skyr
- opulent otter
lynnjen/mod/skyr
- opulent otter
- Eviltoastman
- Part-time Demi-Mod
- Favorite Books: .
- Missin' Jimmy level: 10
- Mobiesque
- deputy wert
- Missin' Jimmy level: 666
I really don't know why more people don't do it. It's also fairly intensive in terms of processing too.
I saw a report on some Aussie safron farms on Landline or some such. They were doing pretty well with it, but as with any independent farming operation, market penetration can be problematic.
'the fuck did I do?
